Dead ICX 7150-C12P
crlloyd1965
Hello support team, I am Lennar home owner with a ruckus IXC 7150-c12p and a WAP. My unit will not stay powered on. When the power is cycled, the amber lights flashes then nothing. I've tried everything suggested on this forum with the same results. What do I need to do to get an RMA replacement?
13 REPLIES 13
Hi @crlloyd1965
Apologies. As we cannot proceed with RMA without confirming if it is a hardware issue.
Before uploading the photos please login to the RUCKUS account on this community portal and you can upload the image.
Lennar Home Community.
The installer used too much velcro over the tag with the serial number. What is the next steps. I didn't dnt realize what an inconvenience not having my home network down would be.
Hi @crlloyd1965
Greetings of the day!!!
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering ON when the Switch is plugged into a well-known outlet/power source. However, the failure persists. This unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
