Connection stability on tvs/iPhones
rjohns503
Hello I am running a 7150 switch and two r510 access points with a Comcast combo modem router. Devices are current on firmware.
iPhones and tvs have slow connection and often drop. My laptop works fine from what I can tell. The speeds are slow usually max out at 400mbs. I have 800mbs service.
Any suggestions? See screenshots.
1 ACCEPTED SOLUTION
Hi @rjohns503
This issue may happen when the Switch runs on the Routing code. The Switch should run on the Switching code to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage may be) which may be running on a ‘Routing Code’ results in causing this issue.
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a ‘Routing Code’ issue which happens due to power outages most of the time, this is a known issue for Lennar home users.
-MAC address: Physical address of the device this never changes
- An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
There are multiple ways to fix this issue as described in below steps:
Please follow the below steps:
1. To fix this issue, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router>
3. Here is a quick guide for understanding how to fix the 'routing code issue' however, you only need to run the following commands once you are on the command line 'CLI'
show version
copy flash flash secondary
(Please share the output screenshot of the ‘show version’ command to check your current version of your Switch running on)
Example:
VIDEO LINK AS REFERENCEhttps://www.youtube.com/watch?v=Eem1IBgYaWc
There are Two ways to fix this issue:
I) How to Fix Routing code issues on Lennar Home users via CLI
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
II) Or WEB access option
4. If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are logged in to the ICX-7150-C12P please follow and perform the same commands that are on point '3'
Lennar Home Community.
5 REPLIES 5
Imran_ruckus
Hi @rjohns503
Hope you are doing well!!!
From the description, I could understand that your ICX-7150-C12P Switch, and R510 APs have slow internet speeds.
Could you also please let us know?
1. From when are you facing this issue or is it a new installation?
2. Was there any power outage or power spike recently?
3. Have you checked that the Internet Speed from your ISP (Internet Service Provider) is working fine or you are getting the expected speeds from your ISP? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC)
Please let us know the answers to the above queries or if you have any queries in this regard.
Thank you again.
Hey I’ve had these devices for a few years in my house just started using them last week. The signal from Comcast is strong that’s not the issue. No power outages that I know of.
Hi @rjohns503
ICX7150-C12 Router>
show version
Example:
Thank you, I tried to get into the CLI before and finally got it dialed in. Everything’s working great now!
