07-23-2026 10:02 AM
07-24-2026 10:40 AM
Hi Smikell731,
Thank you for your post.
Based on the information available from Eero, both network ports on the Eero Pro 7 work the same way, so you can connect your ICX7150 switch to either port.
To my understanding Eero will not replace the old modem/router but instead will enhance the signal it gets from the modem router.
I recommend connecting them as follows:
The Eero Pro 7 includes built-in Wi‑Fi. Lennar homes also typically include separate Ruckus wireless access points that provide Wi‑Fi coverage throughout the home.
You can choose either option:
The choice depends on which Wi‑Fi solution works best for your needs.
Please let me know if this is helpful and if you have any other questions.
07-24-2026 10:41 AM
Also this resource may help:
Thanks.
08-05-2026 09:52 AM
Hi @Smikell731
Thank you.
Yarenis Hernández
