03-11-2024 03:25 PM
After the power outage last week , it has been dropping speeds and lost internet all week.
03-12-2024 05:30 AM
Hi @GideonZ
As per the case description, I understand that your RUCKUS setup is not working with Intermittent Internet connectivity, after a power outage.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
Please refer to the below RUCKUS Lennar Knowledge Base self-help articles to fix this issue.
Please follow the above process and let me know if you need help at any point during the process.
03-15-2024 01:45 PM
Hi @GideonZ
Greetings of the day!!!
Hope you are doing good.
Could you please update on the status of the issue?
Thank you.
