After Power outage, Ruckus wireless routers stop working
vantran
After power outage, my Ruckus wireless routers have no power on and no lights. I used a different outlets, and reset them but they are still not on. Can you please help to fix them? Thank you
1 ACCEPTED SOLUTION
Hi @vantran
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
9 REPLIES 9
Hi @vantran
As per the light status of the RUCKUS ICX-7150-C12P Switch, they are in a normal state.
This issue may be due to the Switch PoE ports getting disabled. Please refer to the below RUCKUS Lennar Knowledge base self-help guide to check and fix this issue.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/NO-Power-on-Access-Points-an...
Hi Imran,
I followed the steps to enable the Switch PoE ports but the wireless routers on the ceiling are not still power on. Can you please let me know what next steps will be?
Thank you.
Hi @vantran
show version
show flash
show inline power
show interface brief
Hi Imran,
They are back online and work as normal when I re-executed the commands.
Thank you so much for all your helps,
Hi @vantran
