03-03-2023 09:54 PM
No power on access points
03-06-2023 01:03 PM
No lights are on. I was able to get to one and plug in an external 12V power supply and it powered up and its working. They do not get POE.
03-06-2023 01:06 PM
The external power supply is a temporary solution for one so that I could have internet access, I can not access the other 2 and I need to remove the external power from the 3rd one.
03-06-2023 01:28 PM
Hi farazkarami
As there are no lights on the Access Points and they are not getting PoE.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
Could you please take the console access to the Switch and share output of the below commands?
Show version
Show inline power
Show inline power detail
Here is the guide on how to console in the ICX-7150-C12P:
Lennar Home Community.
03-06-2023 01:34 PM
I'm using Mac
03-06-2023 02:05 PM
Hi farazkarami
There is a description of getting console access on a MAC Device as well. Please refer to the link shared in the previous post.
Thank you again.
