Access points won’t power on
farazkarami
No power on access points
19 REPLIES 19
tiago1984
Hi I'm also having the same issue here. The power doest reach the access points. Tried to follow the forum but my Mac can't recognize the drivers I installed.
Imran_ruckus
Community Manager
Community Manager
Hi farazkarami
Hope you are doing well!!!
Thank you for the information you shared,
As per the case description, I could understand that your RUCKUS Access Points are not powering up.
Could you please let us know?
1. For how long have you been facing this issue? Was there any Power Outage?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture)
3. Please make sure the Ethernet cable is connected to anyone in the 12 ports shown in the picture below:
4. Also please Make sure it is plugged into a well-known outlet/power source.
5. May I know how many Access Points are connected to the Switch?
Please refer to the below guide for connection setup:
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights.
Thank you again.
Lennar Home Community.
Since last Thursday, after a brief power glitch. Nothing was changed or unplugged on the switch. I have Syst green - power green - no amber lights. I have 3 access points.
Hi farazkarami
As you mentioned that, the SYST and PWR lights are green, meaning the Switch light status is in normal condition.
Could you please let me know the light status on the Access Point? Any of these lights are on (Please refer to the below screenshot)
