Access points has no power after power outage
Srinr
After power outage for about 2 hrs, my Rukus AP devices stopped working, I don’t see any signal or indicator on these Access Points after power back. Please help in resolving this issue.
1 ACCEPTED SOLUTION
Hi @Srinr
As I see from the picture you shared, seems like the ethernet cable which is coming from the Router or Modem/Router combo is plugged into the wrong port on the Switch panel. It must be plugged into any 1 in-12 ports as shown in the below screenshot. Please unplug the ethernet cable and plug it into the correct port.
And as you we can see from the picture you shared there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
19 REPLIES 19
Hi @Srinr
There will be 'ping not alive' error management port on the Switch is unable to contact TFTP server.
Could you please share a picture showing the software recovery cables connections between the RUCKUS ICX-7150-C12P Switch and the Laptop?
Srinr
what are the login credentials here ?
Hi @Srinr
As I can see from the pictures you shared, your Switch is now with a normal light state.
Could you please let me know if you completed the software recovery process and now it is asking for login?
No it is asking login credentials which I don’t remember
