Access points dont have power
Willgomez845
My access point won't turn on after a power outage both system lights are showing green not Amber so don't do the reset not sure what to do here
12 REPLIES 12
Sgatjens
Hi @Willgomez845
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
  1. Was this working before or is it a new installation? If it worked before, was there any power outage before you started facing this issue?
  2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
  1. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
  2. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Kind regards,
Sofia Gätjens
Answer to question 1. The unit was working before.  We have had multiple power  outages  from time to time with no issues.
2.  Both lights are green picture attached
2 access points no lights on either of them
Did you receive the picture?
Hi @Willgomez845
No I am no able to see any attached.
Kind regards,
Sofia Gätjens
