Showing results forย
Search instead forย
Did you mean:ย
Access point power is not on
varunkrissj
I upgraded my ATT wirless modemat home and after that the access point pwoer is not on and also not showing green light on the ruckus icx7150. IMG_4721.jpgIMG_4724.jpgIMG_4722.jpg
18 REPLIES 18
Hello @varunkrissj
Could you please attempt to access the CLI using the Telnet option? Telnet does not require a username or password.
For instructions on how to access the Command Line Interface (CLI), please consult the following RUCKUS Lennar Knowledge Base article:
If you have any questions or concerns regarding this process, please do not hesitate to reach out.
varunkrissj
HelloImran,
The CLI helped me to get all access point power on and now can you provide steps for updating firmware or any other things. its been long time i updated.
Hi @varunkrissj
Please share the below command outputs to check your current Switch version and assist you accordingly.
show version
show flash
varunkrissj
Sure, please find below details
telnet@ICX7150-C12 Switch>enable
telnet@ICX7150-C12 Switch#show version
  Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserv        ed.
    UNIT 1: compiled on Feb 17 2017 at 16:03:13 labeled as SPS08060
      (23946048 bytes) from Primary
        SW: Version 08.0.60T211
      Compressed Boot-Monitor Image size = 786944, Version:10.1.09T225 (mnz10109        )
       Compiled on Sat Feb 18 00:15:43 2017
  HW: Stackable ICX7150-C12-POE
      Serial  #:FEK3229N086
      Current License:
      P-ASIC  0: type B160, rev 11  Chip BCM56160_B0
 8192 KB boot flash memory
 2048 MB code flash memory
 1024 MB DRAM
STACKID 1  system uptime is 3 hour(s) 32 minute(s) 29 second(s)
The system started at 00:02:27 GMT+00 Sat Jan 01 2000
--More--, next page: Space, next line: Return key, quit: Control-c^C
telnet@ICX7150-C12 Switch#show flash
Stack unit 1:
  Compressed Pri Code size = 23946048, Version:08.0.60T211
  Compressed Sec Code size = 23946048, Version:08.0.60T211
  Code Flash Free Space = 1307496448
Hello @varunkrissj
Thank you for your response and the information provided.
Based on the screenshot you shared, it appears that your current Switch is running on an older non-UFI 08060 version resulting in such issues. To ensure optimal performance for Lennar Homes users, I recommend upgrading the Switch to a recommended version.
For detailed instructions on how to upgrade the RUCKUS ICX-7150-C12P Switch from a Non-Unified Forwarding (Non-UFI) version, please refer to the RUCKUS Lennar Knowledge Base self-help article available here:
Since you have access to the CLI, I recommend following the 2nd option outlined in the article.
Please proceed with the upgrade process and feel free to reach out if you encounter any challenges or require assistance during any step of the process.
