05-13-2024 12:50 PM
My access point does not have any power as all the lights are not displayed. The switch appears to be working though.
05-13-2024 01:29 PM
Hi @jpreynol
As per the case description, I understand that your RUCKUS Access Points have no power.
Please let us know the answers to the below query to assist you better.
Please let us know the answers to the below queries to assist you better.
Please let me know the answers to the above queries and let me know if you have any queries in this regard.
05-13-2024 01:32 PM
Hello, was working before.
05-13-2024 01:37 PM
Hi @jpreynol
I see from the picture you shared, that your RUCKUS ICX-7150-C12P Switch has an Orange/Amber light on SYST and Green on PWR. This means the Switch is stuck in the boot mode.
Please refer to the below RUCKUS Lennar Knowledge base self-help article explaining the process to get this issue resolved.
Please follow the process and let me know if you need help at any point during the process.
05-13-2024 02:02 PM
Hi @jpreynol
Please respond on this post, not on the guide article.
When all the lights on the Switch flash amber after some time PWR and SYST lights should turn green. That indicates the Switch is back in its normal state.
If the flashing doesn't stop for a long time, please try to reset the Switch with a paper clip multiple times as described in the guide.
Even if that doesn't work, the only option left is performing the software recovery on the Switch.
Please perform the software recovery as describe in the same article and let me know if you need help at any point during the process.
