01-03-2023 06:40 PM - edited 01-03-2023 06:43 PM
After a recent power outage, my Ruckus switch has one green (power) and one yellow light. Both upstairs and downstairs WAPs have no lights, and our ring doorbell is unresponsive. I read elsewhere in this forum, that someone was directed to perform a reset (hold reset button while cycling power until all lights flash yellow, then release). I did that. It is just permanently flashing yellow now. After waiting about 10 mins, I decided to cycle power again, and I'm back to where I started - One green, one yellow light. I do not have the hardware to perform a firmware update as some have been directed to do. Looks like I will need in person tech help, is that an option?
01-04-2023 08:33 AM
Hi @bryan1775
Basically if the switch has one green and one yellow light, it means that the switch is stuck in boot mode.
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnect it.
If this step doesn't work, we need to perform a software recovery.
01-04-2023 09:56 AM - edited 01-04-2023 10:37 AM
Yeah... I'm not an IT guy. I tried the basic reset procedure as described above, and it did not work. The rest of this is frankly more than a customer should have to deal with. First, I don't have the hardware to complete this task (pc with both USB and ethernet jacks) and even if I did, I still feel like this is a bit much for the end user to have to do. Not impressed with the customer service here, in that Ruckus isn't willing to provide on site help. No offense to the forum here, of course. I just think it's absurd for Ruckus to expect the end user to be flashing firmwares etc.. Lennar is mum on the whole situation too - not much help at all.
01-04-2023 11:34 AM
Hi @ bryan1775
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email. We will be exclusively supporting customers via this community forum support model.
I understand that the steps may be somewhat new, however, we cannot replace the chassis until you confirm that the hardware is damaged. We have tried to create the guides as non-technical as possible, so that they are not difficult to follow; however, if you continue to have difficulty following the steps, I would recommend that you seek outside help or a technician.
01-06-2023 11:02 PM
Hi, was this ever resolved? I am into the same issue and not able to solve this by just reset. How did you resolve this?
