APs don't power and ring bell and thermostats don't have internet access
NP
My APs don't power up and ring bell and thermostats don't have internet access. Tried resetting the Ruckus device hundreds of times but failed.
I wonder there this needs the whole system replaced.
Thank you!
1 ACCEPTED SOLUTION
Imran_ruckus
Hi @NP
Apologies for the inconvenience caused.
As per the case description, I understand that your RUCKUS setup is not working and Access Points have no power.
Please let us know the answers to the below queries to assist you better.
1. If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
17 REPLIES 17
Hi @NP
Thank you for the response and the details.
As described in my initial post, please share a picture of the RUCKUS ICX-7150-C12P Switch showing the light status and cable connections.
NP
Please see the device connected to a working outlet (no light at device input and no light on the status indicating led light on the device. The Ruckus device is dead.
Hi @NP
Thank you for your response.
I kindly request you to refer to my previous communication and proceed with uploading the pictures and a video onto the drive, showcasing the switch connected to the functional power outlet.
For reference, please consult the EXAMPLE videos available from the provided drive link and ensure that the recorded video of your switch follows a similar format.
Once again, I appreciate your cooperation and understanding.
Hi @NP
Your prompt response would be greatly appreciated.
Thank you for your attention to this matter.
Imran_ruckus
Hi @NP
I kindly request an update on the status of the issue so that we may proceed further with resolving it. Please help us with the requested queries.
Type a product name
