AP reset issues
Ringnesgold
My cable provider recently switched out my modem. I could no longer access my ruckus network. I have attempted to reset my AP 7 times, 5 with the app and 2 with the PC. This last time once I was complete, instead of the network I set up recover.me-01570 shows up. I am at my wits end, and I need this due to the size of my house.
7 REPLIES 7
pinky_ruckus
Valued Contributor III
Hello @Ringnesgold ,
From the case description, I understand that you are unable to reset the AP and stuck at Recover.me
I would request you to please confirm if the Switch is connected to the Router/modem combo or to the router provided from the ISP. The Switch should not be connected to the ISP modem directly.
Please verify the connections from the access points and ICX 7150 -C12 P that the cable seems to be in good conditions. Also, the ethernet cable should be connected to 1 of 12 ports in the switch.
Please refer to the short guide link below about how to connect the devices as a reference:
If you have multiple Access Points (APs) in your home, please go to the Ruckus Switch, disconnect from its ports the Ethernet cables of all the Access Points, except the one that you are going to work with. Once the process is finished, connect back to the Ruckus Switch the access points that you disconnected before, and they will connect into the network automatically after a few minutes.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to factory reset the AP and create new Wi-Fi network.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Factory-reset-process-of-the...
Please follow the article and let me know if you have any queries in this regard.
pinky_ruckus
Hello @nicole ,
This post is opened by @Ringnesgold .
Could you please be more specific about the link you are looking for?
We would request you to please open a new post and we will be assisting you through the new case.
Thank you for understanding.
pinky_ruckus
nicole
Please share the reference link.
