AP not working after power outrage
wynn
Lennar homeowner here, last night we lost power for a brief second, now the power is back on; however none of the AP is back on, no lights on the AP. Ruckus router shows power light green and system light yellow. We’ve tried the paper clip reset router trick and it did not work.  We are not sure how to fix. Please help’
4 REPLIES 4
Imran_ruckus
Hi @MikeyH
Based on the information provided, it appears that you are encountering issues with the RUCKUS ICX-7150-C12P Switch stuck in boot mode.
If your RUCKUS ICX-7150-C12P Switch has an Amber/Yellow LED as shown in the picture below that means the Switch is stuck in the boot mode.
Please try hard reset multiple times as described in the below RUCKUS Lennar Knowledge Base self-help article. (Minimum 30-40 times)
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Process-for-performing-a-phy...
If that doesn’t make any difference, Software Recovery is the last option. Refer to the below link guide for the same.
Please let me know if you need help at any point during the process.
Hi Imran,
I tried the hard reset as instructed above, now all the lights are blinking, they have been blinking for a few hours, and the switch is not reset. Do I need to connect the switch with my laptop to complete the reset process? If so, how do I access to Ruckus on my laptop to finish the reset process?
How long should the light blinking last? Mine lasted for hours still no green lights yet. Do I need to contact the switch to my laptop to complete the process? How do I get to the interface on my laptop to complete the reset process?
Hi @wynn
If it continues to blink LEDs, please try the hard reset process multiple times as described in the below VIDEO.
If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
If that doesn't work, please proceed with the Software Recovery process as described in the guide shared in my previous post.
