AP no longer has lights after switch replacement
Dylannn23
Hi. I received a replacement switch which was working fine for a few days. Now after a few days my AP has no lights showing and the internet connection is no longer showing. Below is the status of the switch and the status of the AP
1 ACCEPTED SOLUTION
Hi @Dylannn23
Greetings of the day!!!
Based on the troubleshooting done, your ICX-7150-C12P Switch is not working, and when the Access Points are plugged they are getting power for some time and goes back offline. It's an indication of Switch PoE port issues.  This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
21 REPLIES 21
Dylannn23
Hi @Dylannn23
Could you please try to browse IP address of the Switch in a web browser and login?
Please check the other IP Addresses from the IP scan results, by the name of Ruckus Wireless or Brocade Communications to confirm the IP address of the Switch and try to login.
Thank you again for your patience and understanding
Hello. I am able to open the browser, but it will not let my sign in. I enter my username and password, but the login menu instantly pops up right away. I am using the same log in information as when I initially set up the Switch.
I checked the scan and there are no other devices by the name of "ruckus" or "brocade." Only the one I found which says icx7150
Hi @Dylannn23
Please try the Switch default credentials mentioned in the below:
Username: super
Password: sp-admin
If the above credentials don’t work, you can try below default credential combinations as well.
After one of those combinations I was able to sign in and it required me to change the password. I am now on the general systems configuration page
