ruckus 8200
cajee
hello everyone
I am trying to enable ospf on a ruckus 8200
This is the output from the router ospf command
ruckus#(config)router ospf
Invalid input -> ospf
type ? for a list
soft pkg not supported
The ouput for ? is
Ruckus#(config)router ?
rip enable rip
vsrp enable vsrp
Pretty sure ospf is available on this model.
My version is 10.0.00T253 (rdu1021)
Is it me or the switch?
Thanks in advance
3 REPLIES 3
happytohelp
RUCKUS Team Member
Hi Cajee,
I suspect you don't have L3 Premium license installed. Could you share output of "show license".
cajee
you're correct, but I have paid for a license. Can you tell/send link on how to get the license onto the switch.
Unit License Name L3 Premium Port Speed Upgrade Speed Ports MACsec
1 4X25G No Yes 25G 4 NA
happytohelp
RUCKUS Team Member
Type a product name
