illegal class reported by PD
zadok_ahiya
hi
I've connected some (17) Ubiquiti WAPs to an ICX7150-ZP48.
some WAPs arent loading (all connected with direct patch cables in the lab).
it seems to be randomly not always the same WAP.
"sh inline power" output shows this error"
all WAP are the same model (ubiquitin AC-Lite) and have the same firmware.
it doesn't seem that the switch has any power capacity issues.
I've tried different POE configurations:
"inline power power-limit 8000" (up to 20000)
"inline power power-by-clas 3" (and 4)
and just "inline power"
the switch version is SPS08095d and the POE firmware is 02.1.8 Build 004.
any idea what happing here?
thanks
10 REPLIES 10
BenBeck
Hey There,
What is the model of the Ubiquiti AP? I would like to take a look at the datasheet to check the expected power draw.
zadok_ahiya
@ben_beck
Hi
thanks for responding.
all the WAPs are ubiquiti AC-Lite.
https://www.ui.com/unifi/unifi-ap-ac-lite/
zadok_ahiya
@ben_beck
according to the datasheet, the Maximum Power Consumption is 6.5W.
is that what you referring to?
@zadok_ahiya Right. 6.5W should be no problem, so there may be something else going on. It looks like maybe that model is expecting passive POE. I see there are Ubiquiti adapters for that, but I would have to defer to Ubiquiti. I would recommend opening a case with them and asking about active/passive POE for this specific AP model. They should know if a switch is compatible or if it needs an adapter to work.
