10-30-2025 06:29 AM
This is on a 7150-48zp on 8.0.90d
For some reason yealink phones will just randomly ping out, the port on the switch never loses a connection so it never goes down. I use zabbix to ping monitor a few phones to troubleshoot. Its completely random and it might be 1-5 times a day or never that day. A computer is tied to the pc port of the phone so im dealing with two endpoints on one port. I have tried disabling lldp on it for kicks and then you'll see in my port config, other possible things that could be hitting the phone causing it to go dark for a minute.
Any suggestions on what i can try next before reaching out to support?
interface ethernet 1/1/23
no fdp enable
no cdp enable
dhcp snooping client-learning disable
spanning-tree 802-1w admin-edge-port
voice-vlan 70
broadcast limit 512 kbps
multicast limit 1000 kbps
unknown-unicast limit 512 kbpsI put limiters on but still it dropped. Here is some information on the port.
GigabitEthernet1/1/23 is up, line protocol is up
Port up for 29 day(s) 22 hour(s) 11 minute(s) 48 second(s)
Hardware is GigabitEthernet, address is c803.f524.c004 (bia c803.f524.c004)
Configured speed auto, actual 1Gbit, configured duplex fdx, actual fdx
Configured mdi mode AUTO, actual MDI
Tagged member of 1 L2 VLANs, untagged in VLAN 10, port state is FORWARDING
BPDU guard is Disabled, ROOT protect is Disabled, Designated protect is Disabled
Link Error Dampening is Disabled
STP configured to ON, priority is level0, mac-learning is enabled
Flow Control is config enabled, oper enabled, negotiation disabled
Mirror disabled, Monitor disabled
Mac-notification is disabled
VLAN-Mapping is disabled
Not member of any active trunks
Not member of any configured trunks
No port name
IPG MII 0 bits-time, IPG GMII 0 bits-time
MTU 1500 bytes
MMU Mode is Store-and-forward
300 second input rate: 608 bits/sec, 0 packets/sec, 0.00% utilization
300 second output rate: 10624 bits/sec, 5 packets/sec, 0.00% utilization
555035 packets input, 209050028 bytes, 0 no buffer
Received 171 broadcasts, 5325 multicasts, 549539 unicasts
0 input errors, 0 CRC, 0 frame, 0 ignored
0 runts, 0 giants
2361726 packets output, 1908399128 bytes, 0 underruns
Transmitted 363883 broadcasts, 574652 multicasts, 1423191 unicasts
0 output errors, 0 collisions
Relay Agent Information option: Disabled
Protected: No
MAC Port Security: Disabled
This port is not being monitored for queue drops
Egress queues:
Queue counters Queued packets Dropped Packets
0 2021216 0
1 0 0
2 15876 0
3 0 0
4 100965 0
5 74361 0
6 0 0
7 149308 0 Port 1/1/23 Counters:
InOctets 210283954 OutOctets 1918557531
InPkts 558800 OutPkts 2370630
InBroadcastPkts 191 OutBroadcastPkts 363908
InMulticastPkts 5358 OutMulticastPkts 574774
InUnicastPkts 553251 OutUnicastPkts 1431948
InBadPkts 0
InFragments 0
InDiscards 0 OutErrors 0
CRC 0 Collisions 0
InErrors 0 LateCollisions 0
InGiantPkts 0
InShortPkts 0
InJabber 0 OutDiscards 0
InFlowCtrlPkts 196382 OutFlowCtrlPkts 0
InBitsPerSec 24336 OutBitsPerSec 86792
InPktsPerSec 8 OutPktsPerSec 16
InUtilization 0.00% OutUtilization 0.00%
10-30-2025 08:19 AM
Hi Scott,
Thank you for reaching out.
I understand that the Yealink phones connected to the ICX7150-48ZP randomly stop responding to pings a few times a day, even though the switch port itself never goes down. A PC is also connected through the phone’s PC port. The issue occurs randomly and usually resolves on its own after about a minute.
You have already tried disabling LLDP and applying traffic limiters, but the phones still experience intermittent drops. The switch port shows no errors or link flaps.
Please correct me if I have misunderstood any part of the issue.
Kindly try the following steps and let me know the results:
Temporarily connect only the phone to the port (disconnect the PC or connect it to another port). This will help rule out whether PC traffic bursts are affecting the phone’s performance.
Test on another port/switch: Move the phone to a different access port or another switch.
If the issue follows the phone → the phone may be at fault.
If the issue remains on the original port → the switch port, configuration, or hardware could be the cause.
Try disabling and re-enabling PoE on the port using the commands no inline power followed by inline power.
I hope this information helps you
Please feel free to leave us a message if any concerns
Mayank Meena
10-30-2025 09:00 AM
if we take the pc off, it works fine but the problem is, if we plug the phone into a cisco switch poe, it doesnt lose a connection.
we have multiple phones the ruckus icx, same issue.
I would love to blame the phone but the problem is, it works on a cisco just fine. I should have mentioned that in my description.
So there was a power bump 29 days ago, it would of reset the port, no reason to power it off and on, it will act the same.
appreciate the response.
10-30-2025 09:17 AM
One more note on the issue, the phones with pcs connected, they will lose ping at the same time, which is why i was looking at cdp/lldp/fdp traffic, then did some rate limiting.
