05-06-2024 09:19 AM
I am using an ICX7250-24P with firmware 9.0.10j_cd1. According to the web management pdf saving a running archive from the web management console --> management --> infra is possible using the 'Save Running Config as Archive' button. The PDF references the naming convention for the archive as CX7K_ARCHIVE followed by _## where ## is the archive number. I have set the archive size to 50 but when I try to save the running archive using the mentioned naming format I continually get the ERROR: error - the input file name does not follow the archive naming convention. I have tried several different types of file names - CX7K_ARCHIVE, CX7K_ARCHIVE_0, CX7K_ARCHIVE_1, CX7K_ARCHIVE_00, CX7K_ARCHIVE_01. What is the correct archive naming convention?
05-10-2024 08:44 AM
when i started looking over cfg-archive docs in the 10.0.20 command reference i found quite some inconsistencies (or just plain errors).
instead of posting that whole lot here, what do you suggest? there is always the document feedback email address; but just for cfg-archive i already have 7 different pages with errors (minor ones, like parameters not listed as required, or visa versa , copy/paste errors, those kinda things)
also: any suggestion on how consistency can be reported. cfg-archive for example, the links you provided all speak of "archive naming convention" (with or without a dash), but in the command reference this isn't mentioned at all, they do mention "archive serial numbers" there (which references the 2 digits at the end of the string).
and finally: i have reported a few typos in the actual by opening a case, but this is way to much overhead for us and you, where do i report those?
minor stuff like this:
SSH@campus-core1#cfg-archive management show-current-config
Show the conf_archive configuration
-> i can guess what "conf_archive" refers to, but that's not used anywhere else, either use cfg-archive or configuration archive....
thx in advance
05-13-2024 02:57 AM
Hi Inphobia
Thank you for your feedback.
I would suggest to drop a email to the Ruckus documentation team with regard to error correction or typos. If facing any issue please feel free to let us know. It would be taken care.
05-27-2024 09:46 PM
did exactly that and while it took a few days i got a response & they'll be looking my very long mail to see if this can clear up some confusion.
05-28-2024 06:08 AM
Hi Inphobia
Ack and Thank you for your time in providing feedback.
