VLAN 1 is not working on stack mode
Dear All,
First off please excuses me English isn't my native language.
We have two of Brocade ICX7250-48P stacked, the idea behind is to accomplish a failover , whenever switch one is down we will remain online because each server will have two ports connected to each switch.
the issue is Switch number is working fine so ive configured the second switch as stack see below
the issue as next, when I connect the cable to switch 1 doesn't matter which ports I received IP from VLAN1, when I connect it to the second switch I don't get any ip.
I don't know what I have done wrong can someone please point me to the right direction ?
this the output of VLAN1
PORT-VLAN 1, Name DEFAULT-VLAN, Priority level0, Spanning tree Off
Untagged Ports: (U1/M1) 47
Untagged Ports: (U1/M2) 2 4 5 6 7 8
Untagged Ports: (U2/M1) 47
Untagged Ports: (U2/M2) 2 4 5 6 7 8
  Tagged Ports: None
  Uplink Ports: None
DualMode Ports: None
Mac-Vlan Ports: None
    Monitoring: Disabled
this is output of the brief interface
2/1/1     Down   None   None None None No 141 0 609c.9f4b.808c
2/1/2     Down   None   None None None Yes N/A 0 cc4e.24e3.49ab
2/1/3     Up     Forward Full 1G   None Yes N/A 0 cc4e.24e3.49ac
2/1/4     Down   None   None None None Yes N/A 0 cc4e.24e3.49ad
2/1/5     Down   None   None None None Yes N/A 0 cc4e.24e3.49ae
2/1/6     Down   None   None None None Yes N/A 0 cc4e.24e3.49af
2/1/7     Down   None   None None None Yes N/A 0 cc4e.24e3.49b0
2/1/8     Disable None   None None None Yes N/A 0 609c.9f4b.808c
2/1/9     Down   None   None None None Yes N/A 0 cc4e.24e3.49b2
2/1/10   Down   None   None None None Yes N/A 0 cc4e.24e3.49b3
2/1/11   Up     Forward Full 1G   11   Yes 141 0 609c.9f4b.808c
2/1/12   Up     Forward Full 1G   11   Yes 141 0 609c.9f4b.808c
2/1/13   Down   None   None None None Yes N/A 0 cc4e.24e3.49b6
2/1/14   Down   None   None None None Yes N/A 0 cc4e.24e3.49b7
2/1/15   Down   None   None None None Yes N/A 0 cc4e.24e3.49b8
2/1/16   Down   None   None None None Yes N/A 0 cc4e.24e3.49b9
2/1/17   Down   None   None None None Yes N/A 0 cc4e.24e3.49ba
2/1/18   Down   None   None None None Yes N/A 0 cc4e.24e3.49bb
2/1/19   Down   None   None None None Yes N/A 0 cc4e.24e3.49bc
2/1/20   Down   None   None None None Yes N/A 0 cc4e.24e3.49bd
2/1/21   Down   None   None None None Yes N/A 0 cc4e.24e3.49be
22 REPLIES 22
*Sorry. I also don't see the port settings 1/1/11 to 1/1/12 ethernet 2/1/11 to 2/1/12
@andre_paiva  I appreciate your support.
the NAS LACP is just a test to check the LACP configuration which seems to work.
1. You are connecting a single server that has 4 ports, two of which are connected in the each stack switch
yes this what I am exactly doing. two ports at each switch. so whenever something happens with whatever switch we will remain connected.
but when I connect a Radom pc to the second switch, none of the ports are working, the device is supposed to receive ip from the DHCP server.
is this maybe because the second switch is configured as stand by?
T=52d3h44m21.7: alone: standalone, D: dynamic cfg, S: static
ID   Type          Role    Mac Address    Pri State   Comment
1  S ICX7250-48    active  609c.9f4b.808c   0 local   Ready
2  S ICX7250-48    standby cc4e.24e3.49aa   0 remote  Ready
    active       standby
 -2/3| 1 |2/1--2/1| 2 |2/3-
Standby u2 - protocols ready, can failover or manually switch over
Current stack management MAC is 609c.9f4b.808c
This could be an issue with dhcp server reachability from the pc vlans, Do u have any other PC on same vlan getting Ip from DHCP server ?
You can also open a tac case for one of our tech to look into it.
1. When you connect a Radom PC to the second switch, how is the PVID (VLAN 141) on this port ("show interface ethernet brief")?
2. Is this problem occurring only with other PCs? Is your server connected to the ports (1/1/11 | 1/1/12 | 2/1/11 | 2/1/12) receiving IPs normally?
3. will it be because the second switch is configured as stand by?
I do not think so. As it is in the stack, a master will always be chosen and another one will stand as for the settings and control plan in mode standby.
