VLAN 1 is not working on stack mode
julien_ange
Dear All,
First off please excuses me English isn't my native language.
We have two of Brocade ICX7250-48P stacked, the idea behind is to accomplish a failover , whenever switch one is down we will remain online because each server will have two ports connected to each switch.
the issue is Switch number is working fine so ive configured the second switch as stack see below
the issue as next, when I connect the cable to switch 1 doesn't matter which ports I received IP from VLAN1, when I connect it to the second switch I don't get any ip.
I don't know what I have done wrong can someone please point me to the right direction ?
this the output of VLAN1
PORT-VLAN 1, Name DEFAULT-VLAN, Priority level0, Spanning tree Off
Untagged Ports: (U1/M1) 47
Untagged Ports: (U1/M2) 2 4 5 6 7 8
Untagged Ports: (U2/M1) 47
Untagged Ports: (U2/M2) 2 4 5 6 7 8
  Tagged Ports: None
  Uplink Ports: None
DualMode Ports: None
Mac-Vlan Ports: None
    Monitoring: Disabled
this is output of the brief interface
2/1/1     Down   None   None None None No 141 0 609c.9f4b.808c
2/1/2     Down   None   None None None Yes N/A 0 cc4e.24e3.49ab
2/1/3     Up     Forward Full 1G   None Yes N/A 0 cc4e.24e3.49ac
2/1/4     Down   None   None None None Yes N/A 0 cc4e.24e3.49ad
2/1/5     Down   None   None None None Yes N/A 0 cc4e.24e3.49ae
2/1/6     Down   None   None None None Yes N/A 0 cc4e.24e3.49af
2/1/7     Down   None   None None None Yes N/A 0 cc4e.24e3.49b0
2/1/8     Disable None   None None None Yes N/A 0 609c.9f4b.808c
2/1/9     Down   None   None None None Yes N/A 0 cc4e.24e3.49b2
2/1/10   Down   None   None None None Yes N/A 0 cc4e.24e3.49b3
2/1/11   Up     Forward Full 1G   11   Yes 141 0 609c.9f4b.808c
2/1/12   Up     Forward Full 1G   11   Yes 141 0 609c.9f4b.808c
2/1/13   Down   None   None None None Yes N/A 0 cc4e.24e3.49b6
2/1/14   Down   None   None None None Yes N/A 0 cc4e.24e3.49b7
2/1/15   Down   None   None None None Yes N/A 0 cc4e.24e3.49b8
2/1/16   Down   None   None None None Yes N/A 0 cc4e.24e3.49b9
2/1/17   Down   None   None None None Yes N/A 0 cc4e.24e3.49ba
2/1/18   Down   None   None None None Yes N/A 0 cc4e.24e3.49bb
2/1/19   Down   None   None None None Yes N/A 0 cc4e.24e3.49bc
2/1/20   Down   None   None None None Yes N/A 0 cc4e.24e3.49bd
2/1/21   Down   None   None None None Yes N/A 0 cc4e.24e3.49be
22 REPLIES 22
andre_paiva
Hi Julien
Show the "show configuration" and "show interface ethernet brief" of the two devices.
Tells which ports are connected to the servers and uplink ports.
julien_ange
Thank you for your answer
brief interface
Configuration
Hi Julien,
1. You are connecting a single server that has 4 ports, two of which are connected in the each stack switch
or
2. You have two servers and each server has 2 ports connected to one port on each switch in the stack.
I'm trying to understand your Lag NAS (Ports 1/1/11 to 1/1/12 ethernet 2/1/11 to 2/1/12)
I also don't see the port settings 1/1/12 | 1/2/11 and 1/2/12 in config.
