Unleashed support for ICX7150-C12
jason_decoursey
I am running the following software on my switch: SPS09000a
I created a local user and when I try to add it on my unleashed portal it is stuck on "ICX Switch is Connecting"
I read through the write up here:
https://forums.ruckuswireless.com/conversations/switches/unable-to-add-icx-7150-c12p-switch-to-unlea...
But I wasn't able to resolve my problem. Any advice?
3 REPLIES 3
tim_brumbaugh
Contributor
Do not use version 9.0 yet it is not for production use yet.  Stay on 8.95 or you will have issues and is not supported to connect to a controller for configuration either.  Go back to 8.95.
mohammad_atmazi
Hi Just type this command
aaa authentication login privilege-mode
rob_raper
I had this issue, and this topic kept coming up in searches.   The 'login privilege-mode' command doesn't work in 9.0.x
From other posts, running this on the switch solved it for me:
ICX(config)#crypto key gen ec size 384
https://support.ruckuswireless.com/technical_support_bulletins/631
