04-17-2023 05:58 PM - edited 04-17-2023 06:02 PM
I'm trying to gain access to my ruckus switch via CLI, and I'm getting the following error:
CLI_SHELL_FAILED: SCP_HDLR-TASK ITC_INIT, ITC_ERR[27]
I'm currently on build: 09.0.10eT211. Switch: 7150 24P.
Anyone else experiencing this?
05-14-2023 10:38 AM
Happening the same issue here. When I enter the credentials, the connection gets closed with the message below:
06-05-2023 11:52 AM
Same error on the ICX 8200 with 10 and 10a firmware
12-12-2023 09:30 AM
I also had the same error on ICX 8200 with 10 firmware, however web management was still functioning. I've had a ticket open with Ruckus support, they were very responsive however required console access to investigate this further. Switch is on a remote site, console access not possible, reboot via web management solved it for me. Enabled telnet server now, restricted of course, in case this problem occurs again.
01-09-2024 07:27 AM
same error here, but with telnet same issue however
12-13-2023 04:42 AM
Update received from Ruckus support, this will be fixed in version 10.0.10c which should be released on 19th Jan 2024.
