Ruckus Switch CLI Error
kristphr
I'm trying to gain access to my ruckus switch via CLI, and I'm getting the following error:
CLI_SHELL_FAILED: SCP_HDLR-TASK ITC_INIT, ITC_ERR[27]
I'm currently on build: 09.0.10eT211. Switch: 7150 24P.
Anyone else experiencing this?
9 REPLIES 9
hmarrero
Happening the same issue here. When I enter the credentials, the connection gets closed with the message below:
TimB11
Same error on the ICX 8200 with 10 and 10a firmware
Bamibal
I also had the same error on ICX 8200 with 10 firmware, however web management was still functioning. I've had a ticket open with Ruckus support, they were very responsive however required console access to investigate this further. Switch is on a remote site, console access not possible, reboot via web management solved it for me. Enabled telnet server now, restricted of course, in case this problem occurs again.
same error here, but with telnet same issue however
Bamibal
Update received from Ruckus support, this will be fixed in version 10.0.10c which should be released on 19th Jan 2024.
Type a product name
