Ruckus ICX MSTP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-03-2023 08:32 AM
Hello, we have several Ruckus ICX7150 with SPS08095f.bin version of firmware
Also I have implemented MSTP because I have a lot of vlans and I would like to enable on ports BPDU-Guard and not sure how I can enable It, I mean what is the command?
With per-RSTP you need to enter "stp-bpgu-guard", but which command is in case of MSTP?
Also I have Ruckus ICX 7450 as a core switch and I would like to set "enable" password, but there is no "enable super-user-password " command... How I can set enable password?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-03-2023 08:42 AM
Hey @irakli_gvishian
The bpdu guard command should be the same. As for your core, is it on a different code level (show version) by chance? There are a lot of syntax changes in FastIron 9+. If you are on 9+, that command is deprecated and you now need to do an authentication method list on 'enable' instead and then auth via local account, radius, etc. It would be something like this:
SSH@7150(config)#aaa authentication enable default local
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-03-2023 09:39 AM - edited 08-03-2023 09:40 AM
@BenBeck thanks for your reply,
Code version of core is SPR09010f.bin
Issue with "enable" is with core. I have enable Tacacs+ authentication and authorization for different levels of access and if enter "aaa authentication enable default local" in case of Tacacs+ how do I need to configure "enable"?
In olde versions of code I just enter "aaa authentication login privilege-mode" command and when users logged to the switch they don't need to enter "enable" password.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2023 06:13 AM
This command was initially deprecated with 9.0, but after some feedback from the field, we have decided to bring it back. That work is in progress now and the command should be back in 9010h and 10010b (patch level subject to change). Hope that helps!
