10-16-2025 07:12 PM
I’m using one Ruckus ICX 7150-C12P switch together with five R650 access points to set up my network. All R650s are powered via the PoE+ ports of the switch. In each AP’s management interface, I’ve set the power mode to force 802.3at.
During configuration, I discovered that the ICX 7150’s total PoE+ power output is insufficient (according to the official specs, the total PoE budget of the ICX 7150 is 124W). Specifically, when all five APs are connected to the switch, one AP will fail to power on (its network port LED remains off).
After checking the official documentation, I found that each R650 requires approximately 21.59W of PoE+ power. I then manually set the ICX 7150’s PoE power allocation to manual mode and configured each of the five ports to 24000 (24W). After doing so, all five APs could be detected in the web management interface and showed as being powered via 802.3at.
However, the web management interface became extremely slow and unresponsive—most pages fail to load or time out. If I power off one of the APs, everything returns to normal.
Is there a possible solution for this issue? Thank you.
Switch firmware: RUCKUS ICX FastIron 08.0.95s (GA) Software Release
AP firmware: R650_200.18.7.101.242.bl7
10-20-2025 03:27 AM
Hi Muziyulin,
You can manually restrict the maximum power that the AP can draw.
Example (limit port to 15W instead of 30W):
interface ethernet 1/1/5
inline power power-limit 15000
(Value is in milliwatts → 15000 = 15W)
This can force the AP to negotiate as 802.3af, reducing its power mode and automatically disabling high-draw features.
Note: Please feel free to mark the post as ACCEPTED SOLUTIONS if its addressed your query.
Mayank
10-17-2025 04:14 AM - edited 10-17-2025 05:27 AM
Hi Muziyulin
Thank you for reaching us
Could you please clarify which web management access you're referring to — is it for the Unleashed platform or the ICX switch?
Additionally, if you've tried accessing the device via SSH, could you let us know how that worked? Were you able to connect successfully?
Lastly, are all network services functioning as expected, or have you noticed any disruptions?
Thank you
10-19-2025 05:07 PM
The Web management interface refers to the Unleashed platform. SSH access is only used for the ICX switch. After successfully connecting, I manually configured PoE power supply on LAN ports 1, 3, 5, 7, and 9 of the switch (each set to 24000), and the setup was successful. After configuration, all five APs showed LED indicators. However, the network service did not operate as expected — although there was no disconnection, accessing the Unleashed Web management platform became extremely slow or even unresponsive. Additionally, the speed test function within the AP group could not be used and displayed an “error.” Could it be that the ICX7150 cannot support five R650 APs due to insufficient PoE power supply?
10-19-2025 09:27 PM
Hi Muziyulin,
Thank you for posting your query.
My understanding of the issue is that when all five R650 access points are powered by the ICX 7150-C12P, the switch’s 124 W PoE budget becomes overloaded, causing high CPU usage and making the Unleashed web interface slow or unresponsive. The issue resolves when one AP is powered off, confirming the switch is operating at its power limit.
Please try one of the following options:
Reduce the per-port PoE allocation
Set AP Power Mode to Auto to allow dynamic power negotiation.
Power one AP via an external PoE injector.
Consider upgrading to a higher PoE-capacity switch.
Mayank
10-19-2025 11:36 PM
Thank you for your reply. You’re absolutely right. My current solution is to power one AP via an external PoE injector. I’d like to ask if there’s any way to control the AP to disable unnecessary processes or features in order to reduce power consumption.
