10-01-2023 04:02 AM
Hello. There are 8 floors in our current building. There is a Ruckus Icx 7150-4p Switch on each floor. After the power outage we experienced last week, all of our remote access SSH connections to the devices were lost. I can only connect to 2 devices. I cannot send, including ping, to other devices. Re-configuring the IP on the devices We want it, but the IP address commands do not appear. The written configuration commands are always missing.Looking in the menu of the IP command, there is no Address command listed.Can you Help.?
10-01-2023 04:08 AM
Hi ysnsolak71,
Looks like the switch has booted from the partition with the switch image.
Could you share below outputs:
show version
show flash
show run
10-01-2023 04:12 AM
10-01-2023 04:18 AM
Hi ysnsolak71,
The switch has booted from the primary partition post power outage, hence the missing IP parameters.
Please do the following:
# configure terminal
(conf)# boot system flash secondary
save your configuration
(conf)# write mem
(conf)# exit
# reload
This would boot the switch from the router partition and would prevent the issue in future.
Once the switch boots with the router image, you should be able to see the IP parameters.
10-01-2023 04:42 AM
unfortunately it didn't work. also the first version information I sent you was the device information with my ssh connection. it was a mistake.
device versions I had problems with
