09-22-2022 01:29 AM
HI I have a new RUCKUS ICX 7450-48F. when i try to configure L3 Virtual interface, the below highlighted command are invalid. if i try to configure a port with an ip address command is invalid.
device# configure terminal
device(config)# vlan 2 name Marketing
device(config-vlan-2)# untag ethernet 1 to 4
device(config-vlan-2)# tagged ethernet 24
device(config-vlan-2)# router-interface ve 2
device(config-vlan-2)# interface ve 2
device(config-vif-1)# ip address 10.1.2.1/24
09-22-2022 01:43 AM
You will need L3 premium license if you need functions below.
https://support.ruckuswireless.com/articles/000006815
09-22-2022 05:59 AM
Hey @sogalli
You do not need a premium license just to make a VE. That is included in the base licenses. You may be running the switching image. Please check 'show version' to confirm. SPS code would be the switching image, while SPR code is the routing image. You need to be on the routing image to make VEs.
