05-28-2023 09:09 PM - edited 05-28-2023 09:10 PM
In the Ruckus FastIron Security Configuration Guide under the Configuring QoS priority for a VLAN
it says:
LOUNGE-sw# sh run vlan 1000
Running configuration:
vlan 1000
name "Network Management"
untagged 4-9,11-18,20,48
ip address 10.105.0.18 255.255.254.0
qos priority 7
exit
Love Aruba for simplifying stuff like that.
How do I achieve the same thing on a Ruckus ICX7150-48PF switch. The switch is running router code if that matters and is currently on version 09.0.10eT213.
05-29-2023 09:45 AM
HI dspjones.
Thank you for reaching out.
Checked on this, while I did find that warning on the older release.
however, on the router image on 9010e or higher revision, you should be able to make use of the ACL based
marking system.
given that. where the marking is happening is a layer 3 vlan or vlan with SVI.
Below suggested method should work out well.
> where Layer 2 vlan is defined and ports are associated
> its Virtual interface (ve) is defined with the IP address for the subnet
> extended acl is defined with the marking rule
> and the same is called on the ve as inbound ACL
Do note :
when configuring the ACL you will find below options :
802.1p-and-internal-marking Mark packets with 802.1p priority value and set internal priority
802.1p-priority-marking Mark packets with 802.1p priority value
802.1p-priority-matching Match IPv4 / IPv6 packets with given 802.1p priority value
dscp-marking Mark IPv4 / IPv6 packets with DSCP and COS parameters
dscp-matching Match IPv4 / IPv6 packets with given DSCP value
internal-priority-marking Set internal queuing priority (traffic class)
if the task is to achieve the priority 7 marking : then the second option should do.
if the task is to achieve the priority 7 marking and honor the same as well internally : the first option should do.
Do let us know your thoughts on the same.
Thanks and Regards
05-29-2023 01:21 PM
Thanks for the response. I will try this and report back later.
05-30-2023 04:58 AM
Sure !, Let us know how that goes.
05-30-2023 12:32 PM
Worked perfectly thanks.
