05-23-2024 08:44 AM
Hello, we have 2 ICX7450 in stack. We have enabled OSPF process. I see LSA in ospf database, but there are no routes in Routing table. What can be issue?
Version of software is SPR09010d. OSPF Neighbor is Cisco Router.
07-08-2024 08:53 AM
Hi Asdasdas
Ack and Noted. Thanks for reaching us.
Would you be able to share your running configuration from both switches here on the portal ?
I will check from my end but would take some time.
07-08-2024 10:42 PM
@Hello @Chandini Thanks for your reply,
config related to problematic icx 7450:
config related to non-problematic icx 7250:
05-20-2026 08:10 PM
Hi asdasdas,
Can you share us the running configuration of ve 445, ve 446 of other end device connected to ICX 7450.
show running-config ve 445
show running-config ve 446
show ip ospf interface <<< both 7450, other end device
Thanks,
Vivek
07-09-2024 10:02 AM
Hi Asdasdas
07-09-2024 11:54 PM
Hello @Chandini what it can be? software issue yes?
