05-23-2024 08:44 AM
Hello, we have 2 ICX7450 in stack. We have enabled OSPF process. I see LSA in ospf database, but there are no routes in Routing table. What can be issue?
Version of software is SPR09010d. OSPF Neighbor is Cisco Router.
05-23-2024 09:01 AM
Hi Asdasdas
Thank you for reaching us
If this is a new setup would suggest to upgrade the switch to latest version 9010j_cd2 and then test.
05-23-2024 10:43 PM
Thanks @Chandini for your reply.
We have 2 Cisco Routers ISR4000 (For Failover) connected and established OSPF neighborship with this ICX7450. R2 - is main router and R1 - is standby, all routes are the same from both Routers. When R2 is running, then all routes exists is ICX7450 Routing table, but when for some reasons (for example, ISP issue) R1 became active, routes are gone from ICX7450...
05-23-2024 11:32 PM
Some routes are not learn, this is not new setup
05-23-2024 10:46 PM
Peer between ICX7450 and routers are Point-to-Point (ospf network type), Area 1 (Router 1) and Area 2 (Router 2). Such config works on ICX7250 (SPR08090mc) in another office.
Also there is another device which has established ospf peering with these 2 routers and in case of failover it works good. Issue is just with ICX7450.
