No lights on Ruckus APs
Ampersand
My APs are not receiving power (no lights present) after the ICX-7150-12CP switch was disconnected from power, the switch has two lights present (see attached picture). I read through similar posts on here and followed steps to console the switch with USB-C to USB, which I was able to do. I also followed steps to perform a software recovery but was unsuccessful as I received the following:
ICX7150-Boot>setenv ipaddr 192.168.0.3
ICX7150-Boot>setenv gatewayip 192.168.0.2
ICX7150-Boot>setenv netmask 255.255.255.0
ICX7150-Boot>setenv serverip 192.168.0.2
ICX7150-Boot>printenv
baudrate=9600
ipaddr=192.168.0.3
serverip=192.168.0.2
netmask=255.255.255.0
gatewayip=192.168.0.2
uboot=mnz10115.bin
image_name=SPS08090k.bin
ver=10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Environment size: 189/16379 bytes
ICX7150-Boot>saveenv
ICX7150-Boot>ping 192.168.0.2
bcm_xgs_gmac-0 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Auto-neg error, defaulting to 10BT/HD
Change GMAC speed to 10MB
Using bcm_xgs_gmac-0 device
ARP Retry count exceeded; starting again
ping failed; host 192.168.0.2 is not alive
ICX7150-Boot>
I am not sure if the error was due to not being connected with an Ethernet, the step in which I was required to input an IP address was to be done through an Ethernet properties (see step below), however, my laptop does not have an Ethernet port so I used the properties for the Bluetooth and WiFi (see attached pic). Since I received an error I am unsure what to do next.
Start>type control panel>View network status and Task>change adapter setting>Ethernet>right click properties>Internet Protocol (TCP/IPv4)>Select Use the following IP address>insert the same information I have>Click OK
5 REPLIES 5
Mayank
RUCKUS Team Member
Hi Ampersand ,
I understand that in the instructions there is mention of USB to USB-c cable but that is in context of  console connection only i.e. management purpose as you can see in the below screen shots also .
But here we need a ethernet connectivity between the ICX and laptop because here we are not managing the ICX we are in the process of software recovery .
Type a product name
