Lost POE on two 6450 switches after power outage
Lost POE on two 6450 switches after power outage.
Have multiple ICX 6450 switches deployed in a large store in Oregon.  Thanks to power outages last night...  all the switches came up, but two are not longer providing POE.
Tried reloading, hard reboot by power off/on
Confirmed llpd & cdp enabled
Have no tech support, but do have RMA if needed.
Any suggestions?
Power Capacity:         Total is 740000 mWatts. Current Free is 740000 mWatts.
Power Allocations:      Requests Honored 0 times
 Port   Admin   Oper    ---Power(mWatts)---  PD Type  PD Class  Pri  Fault/
        State   State   Consumed  Allocated                          Error
  1/1/1 On      Off            0          0  n/a      n/a         3  n/a
  1/1/2 On      Off            0          0  n/a      n/a         3  n/a
  1/1/3 On      Off            0          0  n/a      n/a         3  n/a
  detail                        show inline power detailed information
Power Supply Data On stack 1:
Power Supply Data:
Power Supply #1:
        Max Curr:       13.7 Amps
        Voltage:        54.0 Volts
        Capacity:       740 Watts
power supply 2 is not present
power supply 3 is not present
POE Details Info. On Stack 1 :
General PoE Data:
Firmware
Version
02.1.0 Build 004
Cumulative Port State Data:
#Ports    #Ports     #Ports   #Ports    #Ports       #Ports     #Ports
Admin-On  Admin-Off  Oper-On  Oper-Off  Off-Denied   Off-No-PD  Off-Fault
48        0          0        48        0            0          0
Cumulative Port Power Data:
#Ports  #Ports  #Ports        Power       Power
Pri: 1  Pri: 2  Pri: 3  Consumption  Allocation
0       0       48          0.0   W     0.0   W
Any suggestion would be welcomed!
Cheers - James
5 REPLIES 5
jijo_panangat
RUCKUS Team Member
We need to debug the faulty unit to understand if this can be software fixed, Pls work with the tac case owner.
Jijo
