Layer 3 on 7150 ICX
I need help working with and configuring a Ruckus 7150 ICX switch with Router code and programming it for a layer 3 VLAN to run over a layer 2 VLAN product from an ISP.
How do I get the layer 3 piece configured on the core and on the off site device.
Thanks,
3 REPLIES 3
jijo_panangat
RUCKUS Team Member
Hi Jeff,
Pls watch this short video which demonstrates configuring VLAN Routing on a Ruckus ICX switch.
https://www.youtube.com/watch?v=fpicvYXWRhU
Jijo
Thank you. I already have VE's build and IP addresses on the VE's. I have the vlan built and tagged on both sides and running. For the routing do I not have to assign an IP to a port? Should just have the VLAN and VE's work?
You probably need to have route added with next hop pointing to ISP router.
