05-02-2025 01:42 PM
I tried to follow the steps in this article https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-re.... I'm connected to the switch, but no Port shows up. I've downloaded the drivers suggested, and it is still not fixing the issue.
11-16-2025 04:51 AM
It sounds like you’re really close, but this issue usually happens when the connection isn’t being detected at the COM/USB level rather than the switch itself.
A few things you can check:
Verify the COM Port in Device Manager – Even after installing the recommended drivers, Windows may assign a different COM port. Open Device Manager → Ports (COM & LPT) and confirm if the USB-to-serial adapter is actually showing up. If it’s missing or has a warning symbol, the driver didn’t install correctly.
Try a Different USB Cable/Port – Many USB-C or USB-A cables only support charging, not data. Switching the cable often fixes this issue.
Reinstall the Driver Completely – Uninstall the existing driver, restart your system, and then reinstall the driver from the vendor, not the Windows auto-installer.
Check Your Terminal Settings – Make sure your terminal software (PuTTY, Tera Term, etc.) is pointed to the correct COM port and using the right baud rate mentioned in the guide.
Test With Another PC – If possible, try the same setup on a different computer. This helps confirm whether the issue is with your PC or the adapter.
If you’ve done all this and the port still doesn’t appear, the USB-serial adapter itself may be faulty. Replacing it usually resolves the problem.
Hope this helps! Let me know what you see in Device Manager.
11-17-2025 06:03 AM
It sounds like a driver or COM-port recognition issue. Even if the drivers were installed, Windows sometimes doesn’t map the USB-to-serial adapter to an active COM port automatically.
A few things to try:
Check Device Manager → under Ports (COM & LPT).
See if the adapter is listed and note the COM port number. If it shows a warning icon, reinstall the driver.
Try a different USB port or cable.
Some USB-C/USB-A adapters don’t handle serial signals well, so switching cables often fixes the issue.
Verify the Baud rate and settings in your terminal program (115200 / 8 / N / 1 is typical for the switch).
Restart after reinstalling the driver.
Sometimes the COM port won’t appear until a full reboot.
If none of these work, try using a different USB-to-serial adapter. Some Ruckus switches are picky about certain chipsets.
Hope this helps!
