11-21-2023 03:10 AM
Hello
I have a project where cisco will be partly replaced with ICX 8200 Switches. The new Core will be a 8200 FiberStack.
Is there anything important what i have to consider at the uplinkports from cisco and ruckus?
Spanning Tree is set to rstp and simple. Root will be 4096 on the Ruckus.
BR
Bernhard
11-21-2023 03:27 AM - edited 11-21-2023 03:54 AM
Hi Bernhard_rainer ,
Thank you for posting you query !!!
I understand that you are migrating to Ruckus from Cisco and you would like to know if anything important
to consider at uplink ports from cisco to ruckus .
There are some differences in configuration when we move from cisco to ruckus you can refer the below video for your reference :
Migrating cisco to Ruckus : VLAN TRUNKS
https://youtu.be/-zsddysWbsU?si=tKKprxEOwAY8FjDE
Migrating cisco to Ruckus : ACCESS VLANS
https://youtu.be/iEYwA7lVSew?si=BtudLQM4nXLu3Mbx
Migrating cisco to Ruckus : DYNAMIC PORT CHANNEL
https://youtu.be/I2Co84M20Zc?si=0LbMiumtjCkvTsEp
Migrating cisco to Ruckus : STATIC PORT CHANNEL
https://youtu.be/ntxIqBjfwJY?si=x4bNFPUn82UNBUEh
Migrating cisco to Ruckus : STATIC ROUTES
https://youtu.be/ycWYsfkNO2w?si=5XkG9z79WVLHcGJm
Migrating cisco to Ruckus : INTERVLAN ROUTING
https://youtu.be/Bl1pUB03ZvM?si=qGa7ZZF4ZR6695lj
For Spanning tree you can refer the below link :
NOTE: Configuration syntax might change from one firmware to another hence I would suggest you to have a look at configuration guide once.
You can also refer the below configuration guide for your reference :
https://support.ruckuswireless.com/documents/4308-fastiron-10-0-00-ga-management-configuration-guide
Moving Forward If this issue is not resolved , Please log a ticket with the below link so that we will help you further
I hope this information helps you
Please feel free to leave us a message if any concerns
