Showing results forย
Search instead forย
Did you mean:ย
ICX7450 switch STP Loop
We have ICX 7450 switch as distribution switch and below that we have 5 nos HP 5120 as access switches  in a Ring Topology. We have connected one port of 7450 to HP Access switch one and another is connected to access switch 5. If i connect both the link i found STP loop and if i disconnected one of the link, the network found stable. Earlier it was Cisco switch and now we are replacing the same with Brocade.
Please suggest.
5 REPLIES 5
david_ellis_h2n
You need to configure spanning-tree either globally or on the VLAN. I am assuming that the HP switches are default and running PVST 802.1d. You need to match that on the ICX switch. Go to the VLAN and issue the spanning-tree command and set your spanning-tree priority to some number lower than 32768 so it will be the root. This needs to be done on all the VLANs going between the switches. If you want to use RSTP, you will probally need to configure that on all the switches. I know that 802.1w is backwards compatible with 802.1d, but it is best to be all the same if possible.
