11-03-2022 06:31 AM
ı have a ICX7250-48 switches. Now, running Image Version: SW: Version 08.0.30fT211 and I want update to latest version. I'm finding lastest version 09.0.10d for this switch. How can I follow the update path? like a fortinet. Btw, switch configs not important. Its can be reset.
I do think I can't able to install latest version.
Anyone experience this about?
11-03-2022 07:01 AM - edited 11-03-2022 07:08 AM
Hi @taha_colak
Hope you are doing well !
I suggest using the following guide which indicates the suggested destination path if you don't need any functions in the 9010d code if that is your case.
https://support.ruckuswireless.com/documents/1591-ruckus-icx-target-path-selection-guide
1-To go to 8090x+ o 8095x+ we use the 8080f non-UFI version as an intermediate version.
To go to 9010+ versions the upgrade guide mentioned to go to 8095d version first as best practice
Note: Also needed to go 8080f first to go to 8095d
I strongly recommend to read the upgrade guide to the version you want to upgrade and the features needed it.
Here you can find any documentation needed : https://support.ruckuswireless.com/software?filter=105#sort=relevancy&f:@source=[Documentation]&f:@c...
The upgrade can be done via TFTP or USB.
Link as reference : https://docs.commscope.com/bundle/fastiron-08095-upgradeguide/page/GUID-5DD7EE86-6988-4CA7-81D2-22EA...
Note do a 'Write memory' before any upgrade
Best Regards
Fernando Vasquez
11-03-2022 06:57 AM
Hey @taha_colak
Please see this post for code recommendations:
As for the upgrade process, the general rule of thumb right now is the following:
Old code (ex. 8030) > 8080f non-UFI image (be sure to 'wr mem' when you boot 8080f) > 8090/8095/9010 UFI image
You can find more details in the upgrade guides, but that rule holds pretty well as of now.
Hope that helps!
Hi @taha_colak
Best Regards
Fernando Vasquez
11-03-2022 07:55 AM
Thank you Fernando, i appreciate help. When I will reply after do it your instructions.
