03-09-2023 06:03 PM - edited 03-09-2023 06:29 PM
Hi, everyone.
TDR commands were used to inspect the entire network.
When I searched Google for materials related to RUCKUS, there was no clear answer, so I am contacting you
■ Inspection status
It is necessary to interpret the parts indicated in the red box in the above inspection conditions.
Basically, I know that it is normal if the cable distance is the same.
Open: RJ45 Bad Pin Contact
Short: Cable stuck together signal failure
Terminated: Connects successfully
1. Why do I see cable length information in 80-110M instead of 80M?
2. The reason why <=2M short is displayed is that a short occurred at the 2M point?
3. The reason why <=8M Open is displayed is because of the disconnection at the 8M point?
4. Why does Pair A display a question mark?
5. If PairA and D are 80-110M terminated, and PairB and C are 50-80M terminated, is the cable normal? If it is abnormal, why is it displayed like this?
I'm so frustrated whether I can't find the data or I don't have it.
Help me.
Thank you.
03-10-2023 08:19 AM
Hi ChoiYoung,
You are correct, the rest of the show information should be correct, unless you are seeing pair status unknown.
Regards
03-10-2023 03:52 AM
Hi Choiyoungae
From the description I see that you did mention RJ45 cable. Could you please let us know the category of the cable you are using in 1/1/12 , 1/1/4 and 1/1/6 also if you could help us with what devices they are connected to on 1/1/12, 1/1/4 and 1/1/6.
03-11-2023 03:54 PM
Chandini, hello!
All cables use CAT.5e and have APR 310 connected.
Please help me.
Thank you.
