06-25-2020 01:22 PM
SYSLOG: <14> Jun 25 15:30:44 CA-Giancola_Lab_112921 System: Stack unit 1 POE PS 1, Internal Power supply with 124000 mwatts capacity is up
PoE Info: PoE module 1 of Unit 1 on ports 1/1/1 to 1/1/12 detected. Initializing....
2000 log entries of PoE Event Trace Log Buffer is allocated on unit 1 for unit 1
PoE Event Trace Logging enabled for unit 1
PoE Info: PoE module 1 of Unit 1 initialization is done.
SYSLOG: <14> Jun 25 15:31:40 CA-Giancola_Lab_112921 System: SSL server 54.x.x.x:443 is now connected
stack: 01223640 011fe970 b6ba67c1 0051c830 0051cbd4 0052f678 013f7568 0052bd80 011f6b5c b6d1a195
[ 121.869969] [BrcdSoftlockup]: sim_softwatchdog thread is detached on core=0
Application received signal -> SIGNUM#11
Tuning CFS scheduler parameters...
Copying fitrace errorlog file to flash
CORE_PATTERN:PID=828 UID=0 GID=0 sig=11
Thu Jun 25 20:31:42 UTC 2020: Dumping core file to /tmp.gz, this will take couple of minutes ...
Segmentation fault (core dumped)
Thu Jun 25 20:35:14 UTC 2020: Core file collected as /tmp.gz, processing the core file ...
Thu Jun 25 20:35:14 UTC 2020: Removing the oldest core file:core_828-15_2020-06-25_20-20-57.gz of size 7428 kbytes
seq 16
Thu Jun 25 20:35:15 UTC 2020: Calculating checksum: core_828-17_2020-06-25_20-35-15.gz
Thu Jun 25 20:35:15 UTC 2020: Checking integrity of core_828-17_2020-06-25_20-35-15.gz
Thu Jun 25 20:35:33 UTC 2020: Moving core_828-17_2020-06-25_20-35-15.gz of size 7436 KB to flash, with available space of 1281820 KB...
Thu Jun 25 20:36:17 UTC 2020: Core saved as /fast_iron/cores/core_828-17_2020-06-25_20-35-15.gz.
Moving system log files to persistent memory
Core collection and system log collection completed, rebooting the switch ...
Sent SIGKILL to all processes
Requesting system reboot
[ 401.610368] reboot: Restarting system
[ 401.654264] Asserting GHPIO[7] reset sequence from Kernel ...
Ruckus Wireless Bootloader: 10.1.14T225 (Nov 15 2018 - 04:59:18 -0800)
Booted from partition 1
DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Writing Shmoo values into flash .....
device 0 offset 0x0, size 0xc0000
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
06-26-2020 12:37 AM
06-26-2020 10:51 AM
06-28-2020 04:28 AM
