ICX Switch is Disconnected
BAT1610
I moved into a Lennar home a few months ago. I'm trying to setup my network:
ATT Gateway (BGW210-700) -> OpenWrt router -> ICX 7150-C12P  -> 2 R510 APs with:
- Gateway -> OpenWrt router: IP Passthrough
- OpenWrt router -> ICX 7150-C12P: ethernet from a LAN port on the router to port #1 on the ICX 7150-C12P.
- ICX 7150-C12P -> 2 R510 APs: POE
Is the above setup seems reasonable?
While Internet is available via the 2 APs, the switch is showing as disconnected on the Unleashed admin dashboard with the following message:
MAC Address:
c0:c5:20:a9:c6:e5
IP Address:
192.168.1.127
Name:
ICX7150-C12-Router
Failed to ping ICX 192.168.1.127. Suggest checking the network.
How do I fix this so that I can use wired internet?
14 REPLIES 14
Hi  @BAT1610
Hope you are doing well!
As you know the IP address of the ICX 7150-C12p  we can access via ssh or telent
Please downloads a software to access to the CLI of network devices such as Putty or mobaxterm
Mobaxterm
https://mobaxterm.mobatek.net/download-home-edition.html
Putty
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
Once you installed the software log in to the switch
Sometimes ask you for a password we can try the defaults passwords
Username:super password:sp-admin
Or the same as you use to log in to the unleashed dashboard or app
2-Once we are log in into the switch, we should see the next prompt
ICX7150-C12 Router>
Where it immediately tells us that the routing code is running.
3- Must go to Privilege mode
ICX7150-C12 Router>ena
ICX7150-C12 Router#
4-Run a ‘show version’ to confirm which code is running your ICX 7150-c12p
-Show version
ICX7150-C12 Router#show ver
Copyright (c) 2017 Ruckus Wireless, Inc. All rights reserved.
UNIT 1: compiled on Apr 6 2020 at 22:40:21 labeled as SPR08080f
(29829112 bytes) from Secondary SPR08080f.bin
SW: Version 08.0.80fT213
Compressed Boot-Monitor Image size = 786944, Version:10.1.14T225 (mnz10114)
Compiled on Thu Nov 15 12:59:22 2018
as we can see in the initial of the output, SPR08080f is being executed, where the third letter means that the switch is executing the routing code.
Important Note
In Lennar homes, the switch must run SPS (switching) and not SPR (routing) code
5-Once the information is confirmed from the ‘show version’ we should run a show flash
-Show flash
ICX7150-C12 Router#show flash
Stack unit 1:
Compressed Pri Code size = 25976488, Version:08.0.80fT211 (SPS08080f.bin)
Compressed Sec Code size = 29829112, Version:08.0.80fT213 (SPR08080f.bin)
Code Flash Free Space = 1057533952
Here we can see that both SPS is installed in the primary image and SPR is installed in the secondary on the switch.
Here to prevent this problem in the future is to run a ‘copy flash flash secondary’ What this is going to do this command is to copy the primary image to the secondary image, eliminating the SPR image.
Note: if your switching code is in the secondary code we must execute ‘copy flash flash primary’
- ICX7150-C12 Router#copy flash flash ‘primary or secondary’
primary Copy secondary to primary
secondary Copy primary to secondary
Once the command is executed is going to re-flash the images:
ICX7150-C12 Router#copy flash flash secondary
ICX7150-C12 Router#Load to buffer (8192 bytes per dot) ...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
SYNCING IMAGE TO FLASH. DO NOT SWITCH OVER OR POWER DOWN THE UNIT(65536 bytes per dot)...
.............................................................................................................................................................................................................................................................................................................................................................................................................Copy Done.
ICX7150-C12 Router#
6-Once the Step ‘5’ is completed we should run a ‘show flash’ again to verify that both images are running switching code SPS
-Show flash
Stack unit 1:
Compressed Sec Code size = 25976488, Version:08.0.80fT211 (SPS08080f.bin)
7- when completing all the previous steps we execute a 'reload' and confirm the reload of the switch
Note:also you can force the switch to boot up in a specific image:
Boot system flash primary yes ‘to boot up the switch in primary image ‘
Boot system flash secondary yes ‘to boot up the switch in secondary image ‘
-Reload
ICX7150-C12 Router#reload
Warning: Console login authentication is enabled, please make sure users are configured
Are you sure? (enter 'y' or 'n'): y
Running Config data has been changed. Do you want to continue
the reload without saving the running config? (enter 'y' or 'n'): y
8-we should get access to the switch again
ICX7150-C12 Switch>
Here we see that the switch is running the correct code ‘switching ‘
go to the privileged mode and confirm with a show version that the switch is finally running SPS code
-Enable ‘go to privilege mode’
-Show version ‘Check actual version ‘
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#
ICX7150-C12 Switch#show version
UNIT 1: compiled on Apr 6 2020 at 22:29:25 labeled as SPS08080f
(25976488 bytes) from Primary SPS08080f.bin
Hello Can you please share the guide?
BAT1610
It turns out internet is only available intermittently either via wifi or wired. I connected to the two APs and got internet at first. Then after about 15minutes, it stops working. Same with wired.
Hi @BAT1610
Hope you are doing well !
1-As you know the IP address of the ICX 7150-C12p  we can access via ssh or telent
Mobaxterm
Putty
Some times ask you for a password
Username:super password  : sp-admin
Or try the same as you used to log in in to the unelashed dashboard
ICX7150-C12 Router>
ICX7150-C12 Router#
-Show version
Important Note
-Show flash
Stack unit 1:
ICX7150-C12 Router#
-Show flash
Stack unit 1:
-Reload
ICX7150-C12 Switch>
ICX7150-C12 Switch#
