ICX Switch is Disconnected
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-22-2022 01:46 PM
I moved into a Lennar home a few months ago. I'm trying to setup my network:
ATT Gateway (BGW210-700) -> OpenWrt router -> ICX 7150-C12P -> 2 R510 APs with:
- Gateway -> OpenWrt router: IP Passthrough
- OpenWrt router -> ICX 7150-C12P: ethernet from a LAN port on the router to port #1 on the ICX 7150-C12P.
- ICX 7150-C12P -> 2 R510 APs: POE
Is the above setup seems reasonable?
While Internet is available via the 2 APs, the switch is showing as disconnected on the Unleashed admin dashboard with the following message:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-22-2022 07:18 PM
We would need to understand the switch code, config, etc. to really help here. In Lennar deployments our ICX switch should just be switching packets at layer 2; very basic from our standpoint. We are not using any of the fancy features that are available as an enterprise router. I would suggest opening a support case (see my signature) if you need assistance .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-23-2022 06:27 PM
Can you clarify how can I obtain these information: switch code, config?
Also when I login via the Unleashed app, it asks for the Switch username and password. I’ve tried the main username and password that I used to login to Manage Network but it didn’t work out. Do you have any instruction to reset the switch password?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-23-2022 10:24 AM - edited 10-26-2022 01:24 AM
The console port on switches like the ICX don't connect to a standard rj45 network port. They use a special pin out. They are essentially serial ports with a different connector. You can use a USB to rj45 console cable or use a USB C january to connect to the usb c yearly 2023 calendar port which essentially functions as a built in adapter.
There is an amazing guide on serve the home for brocade switches. That is a fantastic switch and access point for home use. If you are not satisfied with the coverage and performance of the r710 especially I would be very suprised.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-23-2022 06:24 PM
can you share the link to the guide?
