Recently I'm having problems saving changes to an ICX 7450-24 stand alone switch (firmware 08.0.90T213):
#write memory
There is no startup config file, unable to save legacy config
flash_fcreat: Failed to create file startup-config.txt
Error - failed to create startup-config.
Flash to Flash Error.
Trying to display the startup-config fails 'cause is empty.
#show configuration
INFO: empty config data in the primary area, try to read from backup
INFO: empty config data in the backup area also
#show flash
Stack unit 1:
Compressed Pri Code size = 32454872, Version:08.0.90T213
Compressed Sec Code size = 32454872, Version:08.0.90T213
Compressed Boot-Monitor Image size = 786944, Version:10.1.15T215
Code Flash Free Space = 1779937280
#show files
Type Size Name
F 32454872 primary
F 32454872 secondary
64909744 bytes 2 File(s) in FI root
1779937280 bytes free in FI root
1777840128 bytes free in /
Any idea?
