08-23-2022 04:57 AM
When I try to add an IP address (IP Address xxx.xxx.xxx.xxx. xxx.xxx.xxx.xxx) I get invalid command for Address.
Looking in the menu of the IP command, there is no Address command listed.
How can I add an IP Address if there's not Address command?
Thanks.
08-23-2022 10:14 AM
With all the information you've given me, I was able to install the 8080f image and set the IP address, subnet, etc... Now I just need to update to the latest firmware. Thank you so much for all the help.
08-23-2022 08:53 AM
If I'm upgrading a switch with an old version 08.0.61.Ct211 to the latest version, what would be the best way to go about it?
08-23-2022 08:58 AM
You will need to use 8080f as a step upgrade coming from that old of code. I would recommend something like this:
8061 > 8080f (non-ufi), make sure to wr mem > 8095g UFI
You can certainly open a case and we can help walk you through the first one.
08-23-2022 10:15 AM
Plus I learned a few things about Ruckus switches.
08-23-2022 10:14 AM
