08-05-2021 01:18 PM
Hi
Does anyone know the default login to ICX 7150 24P?
I thought it was username: Super and password was spadmin?
08-05-2021 01:20 PM
@graham_salters - Very close 🙂 . The default password is sp-admin.
08-05-2021 01:20 PM
08-05-2021 01:47 PM
connect to the console of the switch, boot up, interrupt the boot by pressing b.
enter "no password" and "boot".
11-10-2022 05:29 PM
Ruckus-ICX login:super
Password:sp-admin
Login incorrect
Ruckus-ICX login:
I have followed the steps and can't reset login & password.
Is there a solution?
11-10-2022 06:52 PM
Are you using physical console cable? This cannot be done from telnet/ssh. You will need to continuously tab 'b' during bootup and then you should get boot prompt.
