ICX 6610 IPv6 neighbour cache
dooh
Hi there,
We are using a couple of ICX6610 stacks with ADV ROUTER SOFTWARE PACKAGE and we encounter issues regarding the IPv6 neighbour cache. The stacks are default gateways to a couple of VMware clusters and when we migrate machines between nodes, the IPv6 neighbour cache remains untouched and we need to do a clear ipv6 neighbour vrf aaaa:bbbb and clear ipv6 cache vrf aaa:bbbb.
We are using firmware 08.0.30tT7f3 and 08.0.30m, both do manifest in the same way.
http://docs.ruckuswireless.com/fastiron/08.0.60/fastiron-08060-commandref/GUID-8298B9EF-5CC8-44E2-83... says about ipv6 cache-lifetime but we tried changing ipv6 cache-lifetime to 1 or ipv6 cache-lifetime whatevernumber and does not help, issue remains.
Do any of you encountered this issue or have any ideea?
3 REPLIES 3
BenBeck
It is hard to say on this. I would advise opening a support case (see my signature), so somebody can properly investigate.
dooh
Thank you Ben. Our devices are way out of warranty and out of support, but if this a suspect case and you'd wish, I can open a ticket.
Did you ever figure this out?
I have an ICX7250 and I'm running into the same issue with WAP clients and roaming.
https://forums.servethehome.com/index.php?threads/brocade-icx-series-cheap-powerful-10gbe-40gbe-swit...
If I issue the same clear ipv6 command things start working again.
