ICX 6430
Dmoya
Hello, been using the ICX 6430 24P for some time now. I am looking to upgrade and now I'm asking what would be the upgrade model to this managed switch if I stay with brocade? I would order one with dual power supplies if so. Other than that no change in switch requirement's,
Otherwise, Cisco is being pushed. I think moving my backups would be easier to another brocade than cisco. Any opinions would be helpful.
3 REPLIES 3
BenBeck
Hey @Dmoya
I would like look at either the 7150 or 8200 series to replace your ICX6430.
https://www.commscope.com/globalassets/digizuite/61729-ds-icx-7150.pdf
https://www.ruckusnetworks.com/globalassets/digizuite/993200-RUCKUS-ICX-8200-Switch-Data-Sheet.pdf
Chandini
RUCKUS Team Member
Hi Dmoya
Thank you for reaching us.
Adding to the post you can also refer the below link and look through the switches available and compare based on your requirement.
I hope this helps
Mayank
RUCKUS Team Member
Hi Dmoya
Adding to the post you can also refer to the below link of ICX-DEPLOYMNET-BUYING-GUIDE for you reference :
https://manufacturerstores.techdata.com/docs/default-source/default-document-library/icx-deployment-....
I hope this information helps you
Please feel free to leave us a message if any concerns
