How to confiugure 40g ICX 7750 with
Dandy
Can anyone guide me with 40g as I am configuring with Huawei with dac cable but when I loop it has light and when I insert in Huawei switch it shows incompatible.
This is the below information
show media eth 1/2/1
Port 1/2/1: Type : 40GBASE-Passive Copper 1m (Not supported)
Vendor: CISCO-OEM Version:
Part# : 40G-DAC-3M Serial#:************
ICX7750-48F Router>show media valida
validation media validation
ICX7750-48F Router>show media validation eth
ethernet port number
telnet@ICX7750-48F Router>show media validation ethernet 1/2/1
Port Supported Vendor Type
1/2/1 No CISCO-OEM Type : 40GBASE-Passive Copper 1m (No t supported)
ICX7750-48F Router>^C
@ICX7750-48F Router>show version
Copyright (c) 1996-2015 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Oct 3 2016 at 17:14:14 labeled as NVASWR08040b9
(22909177 bytes) from Primary NVASWR08040b9.bin
SW: Version 08.0.40b9T203
Compressed Boot-Monitor Image size = 1835008, Version:10.1.05T205 (swz10105)
Compiled on Fri Mar 20 06:10:22 2015
HW: Stackable ICX7750-48F
Internal USB: Serial #: ************
Vendor: UB90QBK, Total size = 1914 MB
UNIT 1: SL 1: ICX7750-48XGF 48-port Management Module
Serial #:CRH3*******
License: ICX7750_L3_SOFT_PACKAGE (LID: etjIIGKoFFb)
P-ASIC 0: type B852, rev 03 Chip BCM56852_A2
UNIT 1: SL 2: ICX7750-QSFP 6-port QSFP 240G Module
1500 MHz Power PC processor (version 8023/0022) 88 MHz bus
8192 KB boot flash memory
2048 MB code flash memory
3840 MB DRAM
STACKID 1 system uptime is 24 day(s) 20 hour(s) 35 minute(s) 8 second(s)
The system started at 11:41:27 GMT+05:30 Thu Jan 01 1970
*** NOT FOR PRODUCTION ***
7 REPLIES 7
jdryan
Hi Dandy,
Thank you for sharing that detail, the reason I mentioned that both the ends should be compatible : is as the DAC when connected on 7750 :
1/1/47 No FINISAR CORP. Type : 10GE SR 300m ((SFP+))
1/1/48 No OEM Type : 10GE LR 10km ((SFP+))
We have the part detected, but the same detection raises the not supported warning.
Hence if we use the GBIC for example : say E40G-QSFP-SR4 [ referred from the document ]
you would need another 40G QSFP SR4 rated transceiver on the Huawei end : and same should be able to form an connection.
as here the bits 40G QSFP SR4 are the specification to be matched on both ends,
and once these are matched : rest of the bits should fall in place, with the GBICs from respective Manufacturers,
 Let me know if the suggestion helps,
Dandy
Just to know when I loop the same dac cable on both switch it does get on. GBICs I won't be able to find in the Asian market.
jdryan
Hi Dandy,
Thank you for reaching out,
The issue here is due to the compatibility :
And as the same is a third party cable : we would not be able to guarantee the functioning of the same.
Hence, suggested the solution of GBICs as that could help you over come this compatibility problem.
With respect to availibility of the components, do reach out to our sales team, they should be able to help out on that end.
Do let us know your thoughts on the matter
Thanks !!
