05-01-2023 07:58 PM - edited 05-01-2023 08:06 PM
Can anyone guide me with 40g as I am configuring with Huawei with dac cable but when I loop it has light and when I insert in Huawei switch it shows incompatible.
This is the below information
show media eth 1/2/1
Port 1/2/1: Type : 40GBASE-Passive Copper 1m (Not supported)
Vendor: CISCO-OEM Version:
Part# : 40G-DAC-3M Serial#:************
ICX7750-48F Router>show media valida
validation media validation
ICX7750-48F Router>show media validation eth
ethernet port number
telnet@ICX7750-48F Router>show media validation ethernet 1/2/1
Port Supported Vendor Type
1/2/1 No CISCO-OEM Type : 40GBASE-Passive Copper 1m (No t supported)
ICX7750-48F Router>^C
@ICX7750-48F Router>show version
Copyright (c) 1996-2015 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Oct 3 2016 at 17:14:14 labeled as NVASWR08040b9
(22909177 bytes) from Primary NVASWR08040b9.bin
SW: Version 08.0.40b9T203
Compressed Boot-Monitor Image size = 1835008, Version:10.1.05T205 (swz10105)
Compiled on Fri Mar 20 06:10:22 2015
HW: Stackable ICX7750-48F
Internal USB: Serial #: ************
Vendor: UB90QBK, Total size = 1914 MB
UNIT 1: SL 1: ICX7750-48XGF 48-port Management Module
Serial #:CRH3*******
License: ICX7750_L3_SOFT_PACKAGE (LID: etjIIGKoFFb)
P-ASIC 0: type B852, rev 03 Chip BCM56852_A2
UNIT 1: SL 2: ICX7750-QSFP 6-port QSFP 240G Module
1500 MHz Power PC processor (version 8023/0022) 88 MHz bus
8192 KB boot flash memory
2048 MB code flash memory
3840 MB DRAM
STACKID 1 system uptime is 24 day(s) 20 hour(s) 35 minute(s) 8 second(s)
The system started at 11:41:27 GMT+05:30 Thu Jan 01 1970
*** NOT FOR PRODUCTION ***
05-02-2023 04:10 AM
Hi Dandy
Thank you for reaching out to us. From the details shared , looks like you are using a 3rd Party Transceiver with the switch and looks like its a CISCO vendor
Vendor: CISCO-OEM
Could you please help me with the output of below command. Execute in manager mode.
05-02-2023 05:57 AM
1/1/47 No FINISAR CORP. Type : 10GE SR 300m ((SFP+))
1/1/48 No OEM Type : 10GE LR 10km ((SFP+))
05-02-2023 06:07 AM
Hey,
As i seen the list and as you suggest both ends should be compatible I have Huawei s6720-30C-EI-24S-AC but looping the dac cable it gets enable and light are indicated.
05-02-2023 07:48 PM
Just to know when I loop the same dac cable on both switch it does get on. GBICs I won't be able to find in the Asian market.
